Battery Storage Mode
England - Southwold Suffolk
Anybody have a comment ref the following - LiPo batteries need to be discharged and stored with cell voltages near nominal, at 3.8v. If you haven’t used your battery in a few days, and are not planning to, it’s a good idea to put the battery in storage mode. Damage to the battery can happen in as little as a week of sitting. Again, use a quality balance charger.
So how do we do this with our Typhoon H Pro Batteries?
This is the Best Charger for Typhoon H Batteries
State it up and hover or fly u till the voltage is down to about 14.7 volts while it is going, when you land and stop the motors the voltage comes back up to about 15.1 volts which is not to bad to store them at. I have the eve peak Q 300 charger for 4 batteries and does all batteries including lihv and any other one . Use the other method if you do not have a hobby charger. The stock ones are the worst for your batteries. Johnno Hennessy. Keep flying on the green side of the grass.
Reactions: Yuneec Skins
maikol41
