Steve (Moderator) and I worked on a few questions to help all pilots understand the Breeze operation and functions. Many mishaps occur because we don't understand what will happen when we start pushing buttons or flying the Breeze. Take this short Quiz and test your knowledge!!
1) If your phone does not have dual band wifi, can you still fly the Breeze?
a. What wifi band (frequency) is needed to fly the Breeze?
2) At what height will the Breeze hover when it takes off? Can you adjust this height?
3) How do you set your RTH (Return To Home) height, and what is the current setting?
a. What will happen when you push the RTH button, and how do you cancel it?
4) What determines how high the Breeze fly’s in Journey mode?
5) In Orbit mode, what happens? At what distance will the Breeze orbit you?
a. How do you stop Orbit mode?
6) How do you tell if you have a GPS connection?
a. About how many satellites will the phone see in the Breeze App?
7) If you have no GPS signal, will the Breeze still fly?
8) When flying indoors, how many GPS satellites do you need for safe flight? (The answer is ‘none’, why?)
9) When you FIRST power on the Breeze Controller using an iPhone/iPad what button(s) do you need to push on the controller? With an Android phone?
a. What indication do you get when the Controller connects to the phone?
10) Where, in the Breeze App, does it show how far, and high, you can fly?
a. What is the current setting?
b. Why might you set it for less than the maximum?
11) If you push the throttle stick all the way down, and hold it, will the Breeze land itself?
12) Why should you start the landing procedure before reaching the low battery warning?
13) When should your recalibrate your Breeze? (go through the calibration process?)
If you answered these questions correctly you have a very good chance of not crashing - have fun!
