If the G8302 gimbal is the same as the one from Q500G then those 2 pics may help:
It looks pretty similar to Q500. I have heard that there may be problems with gimbal tilt due to missing initialization (especially valid for CGO2 gimbal).
If tilt will not work as expected you can try to follow instructions here:
Die CGO2 lässt sich nicht von einem normalen Empfänger ansteuern der ein Signal im Bereich 1000us - 2000us sendet.Hier eine kleine Selbstbaulösung.
www.kopterforum.de
Unfortunately in german but pictures and code are international.
Pin in schematic:
IS = input PWM signal from mainboard
IP = input +5V from mainboard
IG = input ground from mainboard
OS= output PWM signal to CGO2
OP= output +5V (not needed, gimbal supplied with +12V from battery)
OG= output ground
