Blue light charging battery
Maybe it’s been discussed but I had the blue light on two batteries.I just pushed the batteries in very hard in the charger and they started charging but they were a struggle to remove.
The yuneec charger and the Gifi power 1300 mah battery.
I’m hoping this push in hard works for all the batteries where you get a blue light it’s worth a try.
The charger for which aircraft? Since you mention a GiFi 1300mAh I am guessing the Breeze.
Others that have used the GiFi have said that it can be a tight fit in the charger and the aircraft.
dharminder
