Breeze 4k Landing Gear
Had my first low battery landing and it caused one of the Landing Legs to break off, I ordered a new set from Yuneec and am now trying to understand how to replace the broken one with a new set... HELP! I asked about a service manual and got no reply can someone guide me? Thank's
54BB259D-E2E9-461E-8F9C-1F41B087DC47.jpeg Give the landing gear 1/8th of a turn anticlockwise and lift away from the arm. To install just reverse the procedure. Be careful with the gear on the legs on either side of the camera as they contain antenna wires.
On the legs near the camera open the gear and leave it attached to the leg. Use a small thin flat blade screwdriver to gently pry off the inside cover to expose the small circuit board and wire.
Now gently pry the circuit board antenna from its cradle in the landing gear. Next you turn the gear 1/8 turn ccw and lift from the arm. Gently feed the wire through the slot in the landing gear. Reverse procedure to install.
Hope this helps.
Reactions: airborne
It is an antenna for the WiFi. There is one in each front leg. You have to be very careful of the wire and the circuit board when replacing either front landing gear.
annaduke
