Breeze
Hi....trying to finally get the time to get my Breeze up and running after purchasing 2-3 years ago. I believe I'm going to have to purchase a new drone battery because of it being dead. I've been charging controller for a couple days now and still getting blue flashing light....seems to be charging so will give more time. Although I could find app on my older Android, I'm having problems finding at this time on Play store with my newer Android. Is there another place I could go to download? I guess at the end of the day I'm wondering if Breeze is too far outdated to try to proceed with. Feel bad, haven't even had it running. Any help would be appreciated. Thanks!
If you have the app on an old phone that will work. All you need is wifi. You don't need cell service. Newer phones won't run the app.
Most certainly you will need a new drone battery. I would unplug the controller and turn it on and see how long it stays powered. After it's drained charge it again to see if cycling has helped.
If you are charging the controller via a USB port on your PC it could take a very long time to charge. If you are using a 1A or 2A USB power block to charge it and it is still not fully charged overnight, then the battery in the controller may also be kaput.
Reactions: WTFDproject
Hi....I'm using a 2 amp block charger. I've left on charger for 2 days then decided to unplug and see how long it will stay on for. It seems to shut off after a few minutes but will restart (perhaps because of inactivity)? I'm going to look around and see if I can purchase another one. I see there are a few on EBay that are Yuneec compatible. Thanks, I'll keep you posted on progress:)
Hi....I currently have a S24FE, I'm guessing it is not compatible? I'm searching for my old S8. I'm having issues with controller so I'll look for another one on EBay. I have 2 drone batteries....charger is staying on standby mode on one and abnormal charging on the other so I'm guessing I need another one of these as well. Just wondering if there's any other way of getting app for my new phone if I can't locate my older one? Just don't want to put out funds on battery and controller if I'm unable to get app? Any help is appreciative, not up on technology here...lol. Thanks.
I replaced the battery on a Breeze controller several years ago. A similar LiPo can be sourced at online battery supply stores. Opening the controller is fairly easy and removing the battery just takes patience to peel it from the double sided tape without puncturing the battery cell. IMG_1903.jpeg
@WTFDproject posted a link in post #2 that takes you to our Yuneec file repository on OneDrive. You have to side load the file. That process can be Googled.
I replaced the battery on a Breeze controller several years ago. A similar LiPo can be sourced at online battery supply stores. Opening the controller is fairly easy and removing the battery just takes patience to peel it from the double sided tape without puncturing the battery cell. View attachment 32178
Thanks....I'll take a look at controller today. Perhaps I can order battery along with drone battery as well. I seen and appreciated posting from WTFDproject, I'll have to google on how to proceed. Thanks again!
You won't find a compatible app for a new phone because the Android version won't allow and older app to run. That is the reason you need an older phone with an older version of Android. You could ask your friends if any of them saved an older phone. Most people seem to pitch them so they are cheap to find.
cpassenheim
