Camera Connection
Vic
Oroville, WA
The notice at the top of my ST-16 says "Reconnecting to camera, please wait___" from the time I turn it on until I shut it off. I'm trying to get this stuff to work in my living room before heading out to an open field. Yesterday, after my first trip out of the house with the drone, and a failure at attempting to calibrate the compass I came back in & fumbled around until I was able to calibrate it about six feet from the controller. I know, I know-----I'll recalibrate it outside! Back to the problem---I'm guessing that I'm not getting a wifi connection between the two units. What's up?
Vic
Do you never get the camera? It’s possibly not bound properly. Do you know where to look for that?
I just noticed your reply---I guess I don't get notified via email when there is a response. I don't believe that the controller & camera are bound. I see that notice now & then. I attempted a calibration today. The camera moved around for 2-3 minutes & then stopped. I got no notice that it had completed nor was calibrated. Also, what am I supposed to do with the login page. Someone said to put in 10 digits & it will work. Not mine!
Vic
I have run this video around 10 times and in no way can I get a blinking yellow light by tilting the H 45 deg. Also, when selecting a camera, there is no C-COG3+ option so I keep getting a "select the right camera" message.
Vic
select CGO3 Pro
Did you try by setting up new model then binding to that? Or start the H first before St and tilt after start up to get flashing bind light? With no ST on its searching for signal and should go to bind when prompted with the three forward tilts.
The tilt routine does not work. I can get the controller & the drone to bind just fine. Can you help me by just working on getting the camera set up properly so that the wifi will connect? Thanks!
Vic
I have no idea what I did just now but the H and the camera are working properly on my living room floor. I shut all systems down and reinitiated them. Both systems binded again so I guess I'm off and running until the next incident. Now, with six new props (after the crash) I'm ready to go flying again.
Vic
Vic
Slow down, breath and have a wonderful flight. So don't run.;)
Write your reply...
wrenchmaster
