Camera tilts
After I fire up my yuneec typhoon h pro drone with the 4K camera, the camera faces down. How do I adjust this
I feel duhhhhh! I found the slider on the left side. I never knew it was there wow. Thank you for the info
If you calibrate the camera, it’s ok to do that with the slider all the way up. You must reboot the TH after that is completed as it will stop off center. The reboot gets the camera back to true forward. If you calibrate the ST, make sure the slider is in the middle at the “beep” spot.
There’s something to e said about reading the Quick Start guide and reviewing the depiction of the ST-16 controls.
Thanks I will do that
Smyers
