Did they give you a Part Number for a replacement Board and Wire Harness? If so, please share. Removing 3 screws and taking the Board out still just leaves you with the same problem, right? Disconnected wiring?And, thanks to talking to Axel P. in Cali, problem fixed. Yuneec has great techs and customer service.
Does someone know the proper wire connection points? I just can't understand fleamac's answer. Sorry.
could you please give me a detailed explanation of how you fixed it? it's a weekend so customer support not available and I have experienced the exact same damage as yours..the 3 wires have snapped off the circuit board. also in my case, the PWM wire appears to have taken a piece of the circuit board with itAnd, thanks to talking to Axel P. in Cali, problem fixed. Yuneec has great techs and customer service.
hi, what cable are you specifically referring to? and how do I use it in place of the wires?I was at Drones Plus in Phoenix, and they had a Q500 in for the "ripped out" wires. They didn't know how to fix it.
Upon close inspection, I found that the three solder pads on the circuit board were clearly marked "PWM" "GND" and "VCC".
Just resolder the wire to the appropriate pads. Install an additional section of wire if the wires are not long enough, using heat shrink to insulate the soldered joint.
You can use the cable that came with the Q500 in lieu of the surface contacts, and not need to do the repair.
RodeoGeorge
