Can’t find Android app for CGO-1
please help
my cgo1 not working
i cant find app to download
older version in android not working
some have this problem to help me
thanks
Reactions: Pier2162
please help
my cgo1 not working
thanks
I am not certain if you have a camera problem or are just looking for the correct Android APP.
This link leads to all the Android App versions I know of that were produced by Yuneec. Most will NOT work with newer smartphones. There may still be non-Yuneec versions on the internet, but those are also most likely too outdated to use with current phones.
If you have access to a really old Android smartphone (from around 2014) it might be a workable solution.
i am unhappy and not found solution
maybe with some firmware update in my camera cgo1 make to work with new app
cgo. or cgo4
it is possible to happens ???
It will very likely not work with the CGO or CGO4 app. The apps are looking for a specific SSID unique to each camera model. If you just need a video stream you can try using a generic RTSP stream viewer like IPCams or VLC.
thanks for your answer
I can’t find the way to see with other program my camera
if you have any idea please tell me. thanks a lot for your time
de
The only thing I can suggest is to find an old phone. I just tried the CG0-1 APP on a Samsung Galaxy S3 and a Samsung Galaxy S4. The APP and the camera worked on both phones.
its not possible to find this old phone
my camera is older cgo1
If it has Ambarella chip and 5G wifi should work, on the CG02+ I've full control of the camera, can take picture and record videos.
If needed, here is available the user manual for this cam :
i know my camera have 5,8ghz wifi transmitter
i read this manual but don’t write witch chip have
after 3 hour to come home from my work test it
and i tell you
and i tell you
and thanks for your time
Reactions: Pier2162
Do you connect to camera wifi first?
I've read on the manual that this camera can be connected to st24 gcs, so this means the wifi should be compatible.
What smartphone are you using? Is it equipped with 5G wifi?
Jesster0430
