- Joined
- Jan 28, 2017
- Messages
- 518
- Reaction score
- 161
- Age
- 72
I am fairly new to this forum and thus far have been an observer and have chosen not to interject my personal opinion, especially in topics I am not well versed, that being said, I can definitely see why ThunderChicken felt you were condescending to him, you don't think telling someone they are making ignorant statements is condescending? There are other ways to educate rather that talking down to fellow posters! You seem well versed on general aviation101.perhaps a brief discussion on adjustable pitch props might be in order.During the early days of aviation engines were relatively weak so a short two blade prop was enough to handle the available power. As early engine development progressed props were changed from wood to metal to better deal with combustion pulses. During WWII engine development increased rapidly, creating engines with enormous levels of power. To use a two blade prop required the landing gear be extended to lengths that were not suitable for the stresses that would be generated, and cause aircraft AoA to increase to the point there was not enough elevator authority to allow a plane to take off, and safely land. The same situation became applicable to Reno Unlimited air racers as they further increased engine output, causing them to adapt wide, 4 blade C-130 props to make effective use of the power without being so long they hit the ground. For a little more propeller development history look up the development of the F4U Corsair and learn why it had “gull” wings.
As for being condescending, I most certainly am not. Your reference to the C-130 prop upgrade was amusing. Not just for those that have been involved with aviation most of their lives, but also for those that have flown in those 130’s and spent plenty of time in conversion with the crews.
For you it’s all guesswork and grabbing at straws hoping for minimal gains to offset the money spent. Others have real life experience and know better. Many times I have switched from a two blade to a three blade prop in aero modeling endeavors. Without fail there was a performance loss in one or more aspects in propulsion function. And all that was when using engines with considerable levels of excess thrust, something a Typhoon H has none of. The study of propellers to obtain more efficiency, thrust, and noise reduction has been a major focus in the UAV industry as those platforms absolutely have to be stealthy and extended mission duration is a very big deal for long duration. With the exception of a few high altitude models they’ve retained two blade props, most of custom design.
Does your arm hurt?Ignorance is a lack of knowledge and understanding. Because a descriptive word sounds rough does not make it inappropriate. Go onto Wall Street without knowledge and experience and start telling people what stocks to buy and why and you would be found ignorant (and likely broke) in very short order. Look up the definition of the word instead id reacting to the sound of it. There are many things in which I too am ignorant.
You can take up the adjustable pitch prop band wagon. When you find one that is affordable and effective for multirotors, let us know. They were employed on the full scales I flew.
Pat
Just to get it out if the way;
Commercial, single and multi engine land, instrument, CFI, BGI, Part 107, mil level UAV operator/maintainer certified.
I give up, I am ignorant compared to you...I will leave with a little philosophy, " man that toots his own whistle so loudly, often is off key"Ignorance is a lack of knowledge and understanding. Because a descriptive word sounds rough does not make it inappropriate. Go onto Wall Street without knowledge and experience and start telling people what stocks to buy and why and you would be found ignorant (and likely broke) in very short order. Look up the definition of the word instead id reacting to the sound of it. There are many things in which I too am ignorant.
You can take up the adjustable pitch prop band wagon. When you find one that is affordable and effective for multirotors, let us know. They were employed on the full scales I flew. When you get started be sure to break out the differences between hydraulic, electric, and fly weight actuators.
Pat
I ran a set of carbon fiber props, got half the flight time, overheated the motors. The one time i ran these not good ill stick with stock props.Hi Dustoff, I would not use carbon probs, they maybe a little quiter and may give more stable flight BUT the downside is if you hit a tree och something like that you might ruin the motor and/or break the arm itself. Or even cut your fingers.. by this razor sharp high speed carbon probs. I prefer to chose the less expensive way to break a plastic prop and save the rest.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
