During the early days of aviation engines were relatively weak so a short two blade prop was enough to handle the available power. As early engine development progressed props were changed from wood to metal to better deal with combustion pulses. During WWII engine development increased rapidly, creating engines with enormous levels of power. To use a two blade prop required the landing gear be extended to lengths that were not suitable for the stresses that would be generated, and cause aircraft AoA to increase to the point there was not enough elevator authority to allow a plane to take off, and safely land. The same situation became applicable to Reno Unlimited air racers as they further increased engine output, causing them to adapt wide, 4 blade C-130 props to make effective use of the power without being so long they hit the ground. For a little more propeller development history look up the development of the F4U Corsair and learn why it had “gull” wings.
As for being condescending, I most certainly am not. Your reference to the C-130 prop upgrade was amusing. Not just for those that have been involved with aviation most of their lives, but also for those that have flown in those 130’s and spent plenty of time in conversion with the crews.
For you it’s all guesswork and grabbing at straws hoping for minimal gains to offset the money spent. Others have real life experience and know better. Many times I have switched from a two blade to a three blade prop in aero modeling endeavors. Without fail there was a performance loss in one or more aspects in propulsion function. And all that was when using engines with considerable levels of excess thrust, something a Typhoon H has none of. The study of propellers to obtain more efficiency, thrust, and noise reduction has been a major focus in the UAV industry as those platforms absolutely have to be stealthy and extended mission duration is a very big deal for long duration. With the exception of a few high altitude models they’ve retained two blade props, most of custom design.
