Carbon Fiber Typhoon H Props
On my second set of carbon fiber props from Carolina Dronz. I cannot get them to lock in to place. It looks like the mounting base is thicker than the factory props and the little flat areas will not slide under the flanges. Has anyone a trick to getting these props on the motor hub and locked?
Probably a good idea to call them at Carolina Dronz, Frank would know.
Have you discovered a worthwhile advantage for Carbon props on the H? Can you share it please?
Thank you. The folks at Carolina Dronz are the best. They sent me a video of carbon fiber prop installation that was helpful. I jury rigged a small channel lock with very thin jaws and softened the jaws with electricians rubber tape. By gently gripping the motor hub with the locks, I was able to get enough torque on the props to lock them down.
Ludwig
