CG03 camera
ok! lol!
my name should be Murphy! so I have the gui installed. but when I connect the usb cable from the laptop to the drone, I get nothing.
The drone just beeps and the motor lights blink 3 times
At this point we can only hope someone recognizes the pattern and can provide information. I tried disconnecting things, different switch configurations and different battery voltage, and never got a similar pattern. The pattern you describe sounds familiar, but I can't place it.
Perhaps @h-elsner, @Enrico Jorysch or someone else will recognize the symptoms.
We have two possibilities for diagnosis:
1) GUI connection
2) Flight logs
To 1):
What OS version do you have?
Is the GUI starting and running in test mode without connection to drone?
Do you get an virtual com port in Windows device manager when you connect the drone (no matter if GUI is running or not)?
To 2):
Could you please download flight logs from ST16? Our analysis tool is now able to go deeper into HW stuff using the sensor files.
Thank you WTF. 🙏👍🫡
I will need to buy a data cable. I have a million usb cables but I don’t feel like going through all of them to find one.
I will return!
Thank you Everyone! Especially /h-elsner.mooo!! 🙏🙏
He may also need to check the cable and connection to the F/C in the drone itself.
Especially the pins inside the connectors. Sometimes a bent pin is the problem, I had this sometime ago and it is hard to find if you don't know where the problem is.
Which connection is that?
Especially check the pins on the flight controller and the USB connector on the flight controller. The USB plug on the outside of the shell leads to the indicated connector on the flight control board. See the image below.
I checked all accessible connections. Double checked the SR24 connection and the flight controller. All seem good. No bent pins. At least that I can see. Man these components are really getting smaller.
Can I remove the real sense wires since I don’t have one?
So now I have the covers of, with a battery in. I noticed that now it has a single beep but the motor lights are still flashing 3 times.
So. I was getting ready to power up when I noticed when I short press the power button, all leds on top would flash blue. The GPS module light flash blue and red. Then nothing when I didn’t see the light on the GPS stay on. Is it supposed to have a led power light with the drone is on?
Sacha
