CG03 camera
here is the flight log. If it matters I was able to access the drone via GUI and all motors responded.
"here is the flight log."
The flight log uploaded fine, but the recorded date of the last flight was back in September. It will take a more experienced reviewer to tell if there is anything revealing from that far back.
"I was able to access the drone via GUI and all motors responded."
Very good. That gives us something to work with in real time.
What is the battery voltage as shown on the GUI?
Reactions: DoomMeister
FlightLogs:
- Sensor files are all empty, even the FW versions are not in. There never was a successful connection for telemetry over WiFi.
- The right stick (roll) is sometimes not centered.
- The only successful flight is #00012. It was very short and for a test flight too close to a building. Go to open area for tests.
- The battery voltage breaks down to 60% very fast (#00012). The battery seems to have a high internal resistance. Not good for longer flights or better to say not good at all.
- Some compass warnings but not serious. I would say it is good. GPS as well.
- Controller GPS also looks good.
What does the battery voltage read while connected to to GUI when the run all motors test is executed?
Reactions: WTFDproject
The voltage with all motors running is 16.7
The weird thing is that after running that test the drone fires up as normal. Normal being flashing amber/orange & blue led.
The ST16 is not recognizing the drone. In settings. I guess I should run the binding procedure?
If the normal binding procedure does not work, re-run the
Typhoon H Binding Verification to see if it will show anything.
This video may help
prestigecarcare
