- Joined
- Sep 26, 2021
- Messages
- 15
- Reaction score
- 0
- Age
- 67
Do you mean the camera is not appearing in the bind menu or is it not available in the camera selection menu?
If you are getting weird unexplainable anomalies on your ST24 a factory reset of the controller may clear up the problem.
I recently had odd behavior on a ST16 controller. I created a new model for the Typhoon H and all looked normal, but it would not arm the motors. I tried three times with the same results. At that point I decided to perform a factory reset. All was well after that.
It is the st24Doing a factory reset on the controller will not wipe out any information that needs to be saved.
This is most likely a refurbished unit and the aircraft and camera should have been bound to the controller before shipping out.
Can you verify the controller you have? Is it the ST16 or the ST24?
I have loaded Yuneec_11000d but it makes no difference. All the manuals say open "select model" but when I do this even copying to a new model, the only option available is the H920, with no camera included. I can start the drone using the st12 and the st24 but with no connection to a cameraYou actually need to select the Yuneec_11000d to connect the CGO4 camera. The password will be 1234567890. It is not very intuitive. You can find the manuals for your system in the Yuneec Downloads on the YuneecSkins.com website.
Many thanks. Yes I can view the camera and take photos. When I put it on RC mode with two controllers st24 and st12 the camera image shows on the st24 but when I go back in to select cgo4 it still doesn't appear on the list.Download the CGO4 app for your phone. Android here CGO4 - Apps on Google Play
or iOS here CGO4
Power up the camera either on the drone or on the ProAction if you have it. Go to the WiFi settings on your phone and connect to the Yuneec_11000d with PW 1234567890. If you connect then open the CGO4 app and see if you have video feed and can control the camera.
So in Team mode you can control the camera and get a video stream on the ST24. Are you able to control the aircraft with the ST12?Many thanks. Yes I can view the camera and take photos. When I put it on RC mode with two controllers st24 and st12 the camera image shows on the st24 but when I go back in to select cgo4 it still doesn't appear on the list.
