- Joined
- Feb 21, 2018
- Messages
- 39
- Reaction score
- 4
- Age
- 63
I've tried to reset my calibration of the left stick in hardware monitor,
Your mention of the word "calibration" worries me a little. Did you only use "Hardware Monitor", or did you go into the secret menu and attempt an actual calibration?
What is the "secret" menu, how do you access it and what do you get out of it....?Your mention of the word "calibration" worries me a little. Did you only use "Hardware Monitor", or did you go into the secret menu and attempt an actual calibration?
It's a method used to screw up your controller and make your camera and aircraft behave erratically.What is the "secret" menu, how do you access it and what do you get out of it....?
Thousands of controllers have been made unusable by the misuse of this procedure than any other cause. That is the reason it is "hidden". If you have a problem with your sticks that cleaning fails to solve then someone with experience using it will direct you in the proper use. Otherwise, just avoid it.
Really???? Your 8th post on the forum and that's the best you can do?keeping this kindergaren hush hush secret, to me is equally stupid and aggrivating
