Correct Firmware Versions
Hi All
New Typhoon H owner here, based in the UK, can someone confirm that these are the most up-to-date firmware versions available for the uk.
Thanks
And their won't be anymore updates for the H so you don't need to worry about updating
That's your lot for updates, it's been superseded, but it is as good as it gets, "oldie but goodie" as they say, it's a stable machine now.
Cheers all, I was aiming to resolve a "WIFi Connecting" Camera loss issue that occurs 3 Mins in to every flight I'm having. Was hoping for an available update.
Where in the world are you? What antenna for video are you using?
Based in the UK, using a Raptor SR that came with the drone when purchased
It's directional so always point at copter. EU firmware to weaker power output, raising the legs can cause video feed loss too. The 4hawks should help though.
It only happens once, I have to re-select the camera in the bind menu and it’s sorted
Sierrarhodesss
