Firmware Question
Q500 4k is working and ready to go. I checked firmware on the cgo3, q500, St10+, and all are running old firmware versions. Should I update all firmware or just use as it as is? I hate to do update and end up bricking if it doesn't go well. Thank you.
...... I hate to do update and end up bricking if it doesn't go well. ....
So do I.
A good plan is that if the system works normally and does all the things you want it to do, just stay on the firmware you have.
Especially if the system is new to you, has been in storage for a while or anything else that may reasonably result in things not working well. You need to fly it first so there is no confusion between existing failures and failures created by an update.
groutmastertampa
