Custom 360 mount for the H.
Hey all, I put together a mount for the gear 360 I thought I would share. Its pretty simple and will accommodate cameras with a 1/4 mount. I cannot remember the exact weight of the unit but it is under what the cgo3+ is. The mount could still use some fine tuning but provided a better shot than just hard mounting it to the H. I will edit when I can get a shot of the whole unit together and mounted, this was done this past summer. The ball joint allows the camera to stay more level during movements. I think it could use more weight to work better. Also the rubber mounts on the yuneec mount help a lot.
So you have two contact plates on the camera mount? Looks like they will short out the contacts on the H.
I just used the blank parts kit so there is no contacts in place. Wish the 360's had a little more wifi range though, I know they are not designed for it but would be cool to be able to watch while it is up in the air.
CBR26
