Download available for "old" H520 US Firmware AutoPilot: 1.8.0-1.6.5
slw74
Part 107 certificate
Matthews, North Carolina
Does anyone have access to the older US autopilot firmware that was released March 22, 2019? I am trying to do a downgrade of the DataPilot on my H520.
AutoPilot 1.8.0-1.6.5
Thanks,
Stephen
Thanks so much. I am going to reset the ST16s tonight with the older DataPilot and load the older FW versions to the H520 and E90. I'll test tomorrow. Once I try flying (weather permitting) tomorrow, I'll update.
Thanks again,
Stephen
Hi,
We performed a factory reset, and unfortunately, the apps did not return.
I tried accessing the link above, but I’m not sure if anyone from the forum could help me.
We have a Yuneec H520 with an E90 camera and an ST16 remote running Android 4.4.
Try this link on Dropbox.
The dataPilot APK is on "Disk 2 (Controller Card - APPS)".
.....and an ST16 remote running Android 4.4.
The labels were wrong on the newer members of the ST16 series controllers. You probably have an ST16S. They look a lot alike on the outside. Real different on the inside. Easiest way to tell is look for visible screws around the gimbals:
Hi,
If the controller still does not work after installing the APK, you can start a new thread to discuss the issue.
You will have to change the controller security settings to allow "unknown APPS" (or something like that) to install the APK. And don't enable or install anything that may pop up during the APK installation other than the APK itself.
revile
