Do you feel you need Realsense? I would do more research before getting a Realsense H, much better to rely on your skills than copters, it builds your abilities and confidence. Realsense can only to do so much and there are still vulnerable areas of the H that could cause a crash. I believe that's vast majority on here don't use it and regard it as a gimmick.
Intel means the Real Sense module. Both versions maintain the same basic H-480 platform foundation. So if you bought an H, simply installing the Real Sense module would change it to the Intel version.
There’s a lot of different names being used to make one or another sound more enticing, along with higher pricing, but in truth they all start out as the same aircraft, with only minor changes in bolt on equipment or added accessories like extra batteries used to glorify the product name.
I agree with the other guy, think hard about the need or frequency of use for the Real Sense/Intel module. Most that bought it never use it.
Buy the cheaper H. Then use the money saved to buy a decent 3rd party charger, that'll give a better return in the long run!Intel means the Real Sense module. Both versions maintain the same basic H-480 platform foundation. So if you bought an H, simply installing the Real Sense module would change it to the Intel version.
The change of direction I mentioned only applies to Smart Mode. I've never had an occasion to use "Follow me" so I'm not sure about how Real Sense behaves with regard to the Mode switch settings.I think it may be worthwhile to point out that Real Sense changes the way the H performs. Normally, when you command the H to go forward or back or left or right it does these while the nose keeps pointing in the same direction. With RealSense activated the H first turns to face the direction commanded before proceeding. I haven't checked this out but it seems that with the camera in Global mode and pointing in a direction different from the direction of flight RealSense could prevent a collision.
I was flying over a field that had a post in it I was intending to fly toward the post and see what the H did as it approached the post. The H was about 6 feet above the ground and seemed to slow down and hesitate at various times. When I reviewed the video it seems that the slowdowns were due to some spindly weeds that I couldn't see from my position but the RealSense detected.
Hello,
Newbie here. Is there any difference with the typhoon h and typhoon h with Intel? On the Yuneec website it seems to be the same thing...
Hello,
YOu can do this with intelesense:Hello,
Hasn't that been speeded up? That flight would of been much slower..YOu can do this with intelesense:
[/QUSome of it but not most of it.
