E90 (Beta) 4K 60fps 100mbs Video Footage
That looks *very* promising. Colour rendition looks good, plenty of range and no obvious problems resolving detail. @Mickeyboo is this the camera you were looking for? :D
I'm going to need a very much faster PC to cope with 4K at 60fps though!!
Reactions: Kev Waite
Thank you, is not too bad without sun.
strongly a native file in 100M / s 4K 60 or 50p
Thank you very much Kev Waite, but i hope to be able to download a native file one day because they are too compressed on You Tube and place it on my time line and see what it has in the belly ;)
Sent you a message Oliver. :)
Indeed. I just received a V60, 64gig card to try in the H. There is a second set of data contacts on the card which may render it incompatible for the CGO3. Works fine in the laptop though. Hope to try it this afternoon.
With the file Yun 0002 and my PC (Intel core I7 6 core 5820K 4.13 Ghz - 16 Go RAM - Graphic card HD7950 - Win 7 64 - monitor Dell 1920x1200)
reading with VLC: processor usage > 25/29%
reading normal speed on time line 1080 60p on Edius 7.58 processor usage > 21/25%
reading slow speed (50%) on time line 1080 60p on Edius 7.58 processor usage > 28/40%
reading normal speed on time line 2160 60p on Edius 7.58 processor usage > 29/44%
reading slow speed (50%) on time line 20160 60p on Edius 7.58 processor usage > 52/71%
Memory used : 6 Go
There should be no problems I've got 3 cards like that and they've all worked fine...depending on what card you've purchased your mileage may vary as they say.
Memory used : 6 Go
I haven't tried but the information is fine. I have the same microprocessor, with more memory and a more powerful graphic. It's going to work well, another thing is the amount of effects and fixes that we put in the videos that usually load a lot of the process. Very useful information, thank you mate
footage is amazing! Very sharp - no real aliasing and smooth. Very good colour!
Footage looks very good, good dynamic range, corner to corner sharpness, can't see any artifacting either!
But at $2000 I still think it's overpriced, will probably wait a while before upgrading from my present H with CGO3+ which is bearable. Raw photos will be interesting when they start to appear to see what can be done with them :)
Yuneecfan49
