Firmware
hi there does anyone know where I can get the bin file TyphoonH.verse3.04/EAccelaromator firmware? If anyone could send me the link or download? Thank you
Hi mate we are running from the old flight controller 1.28 as I was doing a firmware update and my drone bricked I had to flash my drone back to the 1.28 now I can’t find the bin file typhoonH.04/E to the 3.1 to new any help is appreciated
Reactions: DoomMeister
Link to European firmware:
Link to US firmware includes instructions:
@Steve Carr your link was not working. Just takes you to Dropbox login.
"the bin file TyphoonH.verse3.04/EAccelaromator firmware"
"I can’t find the bin file typhoonH.04/E to the 3.1 to new"
I'm not at all certain what you are trying to request, but If you meant "TyphoonH_Ver3.04_E.bin", it is available at this link:
Reactions: 7cyclops
What he needs is the flight controller FW part: TyphoonH_FC_V1.35_3_3_2017.yuneec. This part is not country-specific - you can use any A or E FW.
The TyphoonH_Ver3.04_E.bin (or A) is a zip file that contains all SW parts including the FC firmware. I have a tool to extract the parts: Typhoon H Firmware Tool
You can download it here: Downloads
To make it short - here is the FC firmware part (needs to be unzipped before use).
Is there any where you know where I can purchase an NFZ No Fly Zone release for yuneec typhoon H as it looks like I’m going to have to get a new flight controller and camera. The NFZ I have will not work as the product ID Number will be different, any help is much appreciated
Where did you originally purchase your NFZ release?
At the present time that service may not be obtainable in the US.
You can try contacting @Enrico Jorysch to see if he is able to provide that service.
Reactions: Pier2162
Do you know if I put the Cgo3 pro camera would that let me do the update through the camera?
Do you mean the NFZ? NFZ can only disabled by the Thyphoon H GUI depending on serial number of the flight controller. It is not a different FW but an encrypted code sent to the existing FW. FW update will not help.
when i try to put the nfz on my laptop cut out and i bricked my flight controlar and lose al data form my typhoon h now av had to go pay for another flight controlar and camra so my typhoon h is back up and running and now al need another nfz for my work in the uk if u could help me thank very much , robert
If you purchased the NFZ release in the past then you should be able to return to that source and have them generate a new license file using the product ID of your new controller without charging you again.
Beyond that a web search for Yuneec Service Centers in the UK or Europe may turn up a source for a new NFZ license file.
Reactions: WTFDproject
zayduchef
