First initial Flight
@JulesTEO:
I assure you I was standing outside with the ST16 and the drone. What software did you use to generate that comprehensive analysis?
@JulesTEO:
It is been known that sometimes there are GPS "glitches" on the unit, but I had never heard about one from the ST16 until now, which is very interesting.
Hopefully you will get your unit replaced once the techs run their analysis, and hopefully they will review the dreaded "smart features" which seem to cause an awful lot of misshaps.
I used a program called "q500log2kml" which helps interpret the raw data from the logs, and google maps/earth to draw the trajectory of the ST16
Greetings!
wilko
