Flight-log
Hello, I wonder if a flight in telemetry, writes corrdenadas where the photo was taken.
If so, to which flight log file will find.
Thanks,
Hi,
if you use a SD-Card in your ST10 then you can find three different logfiles.
In two of them, you will find gps coordinates.
Look in the RemoteGPS-Folder to use the easier file.
You can open the file with open office for example as spreadsheet.
Then you have on the left side the date, following with the gps data
Look for the date/time of your photo
Reactions: Anchieta Filho
Thanks for the answer,
But I can not tabulate that way.
In my spreadsheet opens the way it is attached.
Take a look at this. Maybe it'll help. You can also overlay the telemetry onto a Google Earth map, or overlay the data on the video through Dashware. Idk if this help, hope so. They're so much to learn with these birds.
Deciphering telemetry files
If you use Open Office Calc you only have to "drag&drop" the csv-File.
A box pop up and aks how to import your file.
Select: separated by commas
In the infowindow you can see what happen to your selection
You can use both date - latitude + longitude - and ask google where this is.
.................google.de/search?q=53.07518 7.8968587
Might be a dumb question but how do you get the sd card out of your controller? mine is in such a tight spot i can't.
Don't remove the card if you don't have to.
Connect the box to your computer through the usb port.
See if Windows will see the box and try to navigate to the SD card and telemetry files in the box.
If Windows doesn't see the box.... Look here:
Strange happenings
Good luck,
Jafo
DHYradio
