Gimble Firmware 1.39.6 issues
Peggy
Premium Pilot
Well I have come back from a job today and about to start editing and I could toss the 520 into the nearest river. Issues is so slight that it didnt notice on the ST16s screen at the time.
I test flew the latest firmware when it got released.
E90 latest firmware
Datapilot latest
flight controller latest firmware
Gimble firmware latest 1.39.6
No issues at all.
Today completed job and guess what there is gimble bounce on all the footage
Here's a link to the raw footage, it's unuseable.
Downgraded back to 1.38.8 and the problem seems to have gone away.
Team (slave) Mode still works on that firmware as well.
Anyone else suffering from the bounce?
Reactions: ;-)
E90 latest firmware
Datapilot latest
No issues at all.
If you need the footage are you sure it's unusable? Seems would be an easy fix with Mercalli. It would at least allow you to save the work. I'll re-test and see what I have...
@Peggy ; went out and did a short test and uploaded direct from the card, with Gimbal 39.6...
Looks pretty good, but let me know what you think..
Hi 10-8
That was one of the shorter clips as I wanted to upload the raw to show.
I havent tried stabilization yet in post edit. I was just annoyed at the time and uploaded it to see if anyone else has this issue.
I'm going out today for a test flight now I'm back on 1.38.8
I'll see how that goes bud.
Your flyover of the house seems perfectly stable, so seems its an isolated issue my end. Thanks for your time bud
Update:
Turns out the only thing that will stop the wobble (and I have tried every Gimble and E90 Firmware) is to actually roll back the flight controll to 1.4.2
As it stands for the time being the wobble has gone.
E90 latest firmware
Datapilot latest
No issues at all.
Hi Peggy
confirm this -
the same is here on a test E90 same updates ( 1.39.6 )
did try a gimbal calibrate too , but this not helped.
will try to roll back gimbal fw and let you know.
thanks for let us know this -
best wishes
edit:
did not helped me too.
i did calibrate RC too - no better things comes
"roll back the flight controll to 1.4.2"
"As it stands for the time being the wobble has gone."
You did completly roll back the flight controll to 1.4.2 and the wobble has gone?
..so must search first where i get the 1.4.2 ..****.. :/
Hi Peggy
confirm this -
best wishes
edit:
Yes I can confirm 1.4.2 the wobble has gone.
Everything else is on the latest firmware
Reactions: arruntus and ;-)
sakshijah
