Global gimbal mode in CC
I used to fly a Russian aircraft (full size), where the artificial horizon worked the opposite way around to a western aircraft... down was up and visa-versa, I ended up being able to use the AH whilst flying.... but with very sweaty palms and an accident waiting to happen....deep seated learning can be difficult to over-ride :)
Prop prolly went the wrong way too. I agree, it can be a bit of a chore to adapt. I'm terrible at driving in countries where lane directions are reversed.
Hi!
For me the gimbal mode at CCC is also confusing.
I fly FPV quads and pushing stick forward quad nose goes down and horison goes up on my goggles.
Typhoon H in CCC mode does opposite. Stick down moves camera down, not related as flying FPV.
I would like to have option to change it!
Best regards!
Reactions: abinder
Hi!
Best regards!
Have you contacted Yuneec? Complaining about it here certainly won't change anything.
Enough people discussing this with Yuneec C.S. would probably get it changed in a later firmware release.
I said something to them a couple of months ago and the person I talked to said there wasn't any plan to change it and it might be hard for them to do. Go figure.
Here is a video that shows how to change the channel settings to control the camera. It is in German. If you decide to do this, make sure to create a new model and make the changes on that one.
As a programmer, I'm thinking it would change one line of code, maybe a plus sign to minus...
I'm not a programmer but do work with autopilots. A lot of what I work with uses a binary code and positives/negatives are common to the flight surfaces logic in Phi, Theta, and Gamma, along with payload control functions.
I spoke with Yuneec UK CS to ask if reversing the function was possible. The answer was no, but fwiw they did say that it would be a very useful option to have and that they would pass this onto their R&D guys for consideration.
trademark analystip
