H 520 Camera/Controller Issue
lsn618
Premium Pilot
Pennsylvania
For some reason when I start up my H 520 I can't pull up the camera on the controller. I have tried to rebind the camera but it doesn't appear. Any suggestions?
Does the gimbal stabilize?
Does the camera appear to power up (camera LED flashing)?
Is there a small flashing LED in a pinhole on the rear arm of the gimbal?
If the camera powers up, can you see the camera Wi-Fi signal on your home Wi-Fi or Phone Wi-Fi?
Can you see the camera WI-FI signal on the ST16S in Pad/Settings/Wi-Fi?
Just a thought, REMOVE the camera and CAREFULLY Clean the Contacts on both the Camera Connection and the H520 Connector.
It is possible some crud has built up on the contacts. Use a pencil eraser, again Carefully!
Just a thought!
colaraz
