Help: Chroma Blade Drone With Yuneec CG03 Gimble/Camera
I inherited a Drome from a privious instructor. After fighting with it for a little while I realized the control board for the gimbel/camera is missing and there are just a bunch of wires with plugs on the end hanging out of the top of the gimble.
1. Whaat control board would I need to buy?
2. Are there any instructions for wiring it?
Can you make a picture of the current situation?
The gimbal board wiring is here:
More info: WTFD project, table of content
Reactions: Pier2162
Ok, next issue. USB cable.
Anyone know the pin out to usb for the USB prot on the controller board so we can make our own cable?
Update: It is not fully clear which board you mean;
If you mean the main board of the ST10+ Controller, stay in this post.
If you mean the main control board (ESC Board) of the Chroma, see Post # 11.
If you mean the gimbal board of the CGo3, see Post #12.
The ST10+ controller port is a standard USB micro b port. It works with Data Capable USB cords you can find at most retail outlets. The common USB charging cables look exactly the same, but will not work for anything other than charging the battery.
If you have a special need to build your own cable, you can do a web search for:
usb micro b port pinout diagram
usb micro b plug pinout diagram
This one might have all you need:
It has a lot of information, including this pinout drawing:
Someone more familiar with USB might be able to help interpret this stuff.
Reactions: Pier2162
I believe he refers to the Update Board: Chroma, BLH8605.
There is little support. by quick search I found one in Switzerland:
Best way to get a source is to search for BLH8605.
I could not find an actual pin out for BLH8605. This is how I read it. Use at your own risk. Maybe someone else will comment.
Reactions: h-elsner
OK. The third interpretation.
If you meant the connector (pig tail) port on the CGo3 gimbal board, this is the drawing linked by @h-elsner in Post #2. Zoom in close and look at the three lines leading into the pigtail connector.
These cables are pretty common on eBay, except you can expect a week or two delay if it comes from China.
FlyingVegetable
