H520 main board
RPG
I need a complete main board for a H520. If anyone has a good one please let me know.
Does anyone know of a source to get the h520 main board schematic. I'm trying to find out what the parts are with ADEG 150 . I believe they are part of the motor circuitry. I have noticed a drop of sorter against a d e g and it touches a circuit next to it. This is located on the motor that I've had failure problems with. I would like to see the schematic so I can understand how that circuits put together. Maybe my fix to the older problems
It is. It needs to come off. Not the first stray solder drop we've seen on a Yuneec board.
If you can't remove it yourself, you might find an electronics / computer repair shop that can help.
Unfortunately, the existence of the solder may have already damaged something. You won't know until it is removed.
I believe that's the problem but as you said the damage may be done. I received another board and had it half connected and saw two motor wires are missing. Now I don't know if somethings wrong or not. It's a gift that keeps on giving. I'll remove this tomorrow and we'll know if it's good or bad
I couldn't find datasheet for those circuits but I'm pretty sure that this are dual "Gate Driver" for the MOSFET bridge. The MOSFET bridges control the motor coils.
The number after ADEG is different from board to board (a lot number?). A problem with those driver may cause defect MOSFETs but the drivers usually contain a overcurrent protection.
You will never get a schematic of the H520 board but the principle is here for example:
The gate driver in this example are IR2301
Thank you for the information. Seems that this forum has more intelligence than the manufacturer. I'll know if the removal is a fix later today.
mow80198
