H520 ST16S stick tension adj.
You cannot adjust them. You might be able to fit stronger springs but then you need to be careful about damaging the gimbal scissors (parts the springs attach to).
I opened mine up within a week of getting it to confirm this. Gimbals are non-adjustable in the ST16S.
It is also a question of seeing exactly which model they are and looking for some that if they are, the sticks in the modern radios, is the first thing that is usually changed when you give it a lot of use.
Did you, by any chance, take pictures?
dharminder
