H520E RTK update problem
...I will look for the cable tomorrow....
Work carefully if you decide to try the OFDM cable from the other drone. The wires are very fragile where they spread out at the connectors. If you tug on the wires, they will break off. If you slip when using a sharp tool to gently raise the connectors, the wires will cut at a touch. It is best if you disconnect one end completely before starting on the other end to avoid accidentally stressing the wires.
I have already replaced several of these "cables".
It is the connecting cable between the OFDM module and the X-Connector.
Remove the gimbal... Open the OFDM module box... Replace the cable and put everything back together again, takes 20 minutes if you are a bit practiced.
The connections of the cable are identical and the cable is long enough that no strain is put on it.
I laid my last connection cable today... I received a few H520Es over the last few days where the cable was damaged.
Repairing the cables is out of the question... under the magnifying glass I saw 27 fine wires... was difficult to count.
I reordered 3 cables 8 days ago... I have not yet received them.
*** Translated with www.DeepL.com/Translator (free version) ***
Unfortunately, however, after replacing the cable, it is still the same, i.e. there is an image but the camera does not spin. It passes all tests and calibrations and still no movement. The question is what to do next?
Is it possible that another cable or any board is damaged?
Unfortunately, however, after replacing the cable, it is still the same.
That could be viewed as a good thing. The cables are hard to find. If we find the issue in something that can be fixed at home, it is much better.
Yes. The OFDM cable was by far the most likely. Finding the next may be more difficult.
I would start by swapping the OFDM module between the two drones.
It passes all tests and calibrations.
Please clarify which tests and which calibrations you are performing.
How are verifying the drone itself is actually bound to the controller?
Reactions: DoomMeister
When the drone is switched on, the camera performs the standard test as usual and stays horizontal and after a while connects to the controller.
Next is the test in the controller "Monitor" and "Calibration" and here too there is no problem.
As for the control as I check the connection to the drone it is via the icon ‘unbind’ and ‘bind’ connect and disconnect on the back the LED lights up in a steady blue colour. Previously I connected cameras and controllers crosswise and in the other everything works (camera and controller) and here nothing.
"via the icon ‘unbind’ and ‘bind’ connect and disconnect"
"the LED lights up in a steady blue colour."
The solid blue should mean "manual Mode". It would be good to cycle the flight mode switch to ensure the drone is changing between blue, purple and yellow. (the purple may blink if GPS is not acquired). If the colors don't change, the OFDM is not bound. You can also try to bump start the motors (with no propellers).
The H520E manual section on OFDM has more steps and involves a button and some indication on the back of the OFDM module. Are you also performing those steps?
Are you getting the green check mark on screen as shown for Step 9 of the bind process?
See page 12 of the attached manual.
I have a question, what is this board that all the wires are attached to and the OFDM module is plugged in for?
This is part of the OFDM module.
The remote identification module, which is required in Europe to certify the C2 drone, is connected to this board.
The RTK module, if available, is also connected to this board.
I call it the interface distribution module.
The connection cable between the OFDM module and the X-connector is connected on the underside.
Thank you for the explanation ‘Enrico’ while I still have a problem with the drone and do not know how to solve it. I have replaced this board and the cable and there is still a picture but no camera control and I don't know what to do next myself anymore.
There are two boards in the OFDM module. Did you change out both of them?
Also, have you traced the wires back to ensure the other end of each item is connected as it should be?
I will check
The quickest way to check is to move the camera to the other drone and confirm it is still working as it was when swapped over in Post 18 above. If the camera and gimbal still work while mounted on the other drone you may want to avoid taking it apart. There is always a chance of damage when doing maintenance.
Reactions: Enrico Jorysch
nayansharma
