H920 Plus lighting
What kind of night lights can be mounted on the H920 plus drone...? And where can you purchase them...?
Does Lume Cube carry any the fit the H920...?
The mounts that attach the LumeCube for the Inspire are a clamp style and should work for the H920. The tubes on H920 are 21mm and the Inspire are 22mm. If they were too loose, all you’d need is a small strip of shim stock; piece of inner tube or bicycle shops have various thickness rubber strips for various clamps.
LumeCube | Portable, Durable, Powerful Lights for Photo and Video
I didn’t realize the LumeCubes could be controlled by Bluetooth. Able to remotely turn On/Off and adjust 10 levels: 150-1500 Lumens.
Jkent8541
