- Joined
- Jun 8, 2016
- Messages
- 874
- Reaction score
- 357
- Age
- 76
Here is a short clip showing a simple use of the cruise control to pan the aircraft while automatically yawing the camera.
When you say "automatically yawing the camera", do you mean the Typhoon H yaws the camera/gimbal without you doing anything while you are using the right pad as a 'cruise control' ?Here is a short clip showing a simple use of the cruise control to pan the aircraft while automatically yawing the camera.
Yes. I rotated the gimbal yaw knob to the right a bit, tapped the trim pad a few times to start the H flying forward and then flip the gimbal switch to global. The H flies and pans the camera automatically with hands off.When you say "automatically yawing the camera", do you mean the Typhoon H yaws the camera/gimbal without you doing anything while you are using the right pad as a 'cruise control' ?
Okay. Now I see what you meant.Yes. I rotated the gimbal yaw knob to the right a bit, tapped the trim pad a few times to start the H flying forward and then flip the gimbal switch to global. The H flies and pans the camera automatically with hands off.
A similar action but with manual increase of altitude.
