Help Choosing a Charger Q500 4K
Hello everyone,
I'm trying to find the best all-in-one charging solution out there for my needs at around $100 or less. I'm new to the hobby and the Q500 4K is my first drone . I'm using a GiFi Power 7500mah 3S Lipo flight battery in the bird and I recently bought a Zippy 1000mah 3S 11.1 25-35C FlightMax lipo for the steady grip mod. I'd like to be able the charge the ST10 remote with whatever I buy as well. The SkyRc D100 and HiTec X2 are popular choices for this model from what I've seen. What would be the best option, and are there any extras I would need to pick up? Open to other suggestions as well. I'm trying to keep things as simple as possible and would prefer to not have to pick up an external supply or solder anything if I can help it.
Thanks in advance,
Cody
To save battery problems and store the battery at a safe level I invested in these:
https://www.amazon.fr/s/ref=nb_sb_n...steur+tester+monitor+Buzzer+Alarme+indicateur
and
https://www.amazon.fr/GoolRC-Profes...4483&sr=8-1-spons&keywords=imax+b6+mini&psc=1
Now I can charge, discharge and set the battery to storage levels. The tester will show that each of the three cells is at or very near 3.8 for safe storage and no deterioration.
I also got three new batteries: 1xMorpilot 6300mAh very good and
2x GiFi Power 7500mAh feels like it doesn't want to land - stays up for ages.
I use the adapter from a monitor to power the charger.
Works great for me - Hope it helps.
Fly safely out there.
I use the Hyperion EOSO72i Net3AD its a programable charger that's smart and user friendly. Just tell it what you want and its done..Hyperion E.png
Venom Pro Duo is the way to go for me.
PHP:
https://www.ebay.com/itm/Venom-0685-Pro-Duo-Dual-80W-AC-DC-LiPO-LiHV-NiMH-7-Amp-charger-Losi-Associated/163492683161?epid=12013919142&hash=item2610ec5d99:g:nyIAAOSw64xcN6wt:rk:2:pf:0
Happy flying and good luck,
Jafo
LorieMcCor
