HELP! Lights on power up
I'm colorblind but the wife helped out. I've calibrated my compass numerous times and had to re-bind.
Every time I power up:
Switch in Smart Mode: Blinks Green + White
Switch in Angle Mode: Blinks Purple + White
I can't find these combinations anywhere! Little help please!
I'm about ready to throw it in the trash can.
In angle mode:
Purple/White is angle mode with GPS lock AND enough GPS on ST16 to do watch/follow me.
Purple flashing is angle mode without a GPS lock
Solid purple is angle mode with GPS lock but not enough GPS on ST16 for watch/follow me. (I usually never see this one as the ST16 gets a lock about the same time as the H)
So I'm actually "better" than OK then? Wow. One would think those lights would be noted somewhere!
Reactions: Goh
Flew it and everything seems fine given the lights are not documented. The only thing I had any issues with was auto-takeoff. Doesn't bother me because I will never use it anyway but when I tried, it said something to the effect, "Cannot auto takeoff. Aircraft not ready." Any ideas?
terryguindon57
