Help with the wizard
I have a new typhoon h, I did not get the pro model even though at this point I should have, I did research and wanted to add the wizard, everything I saw said that it is compatible with the typhoon h, when it arrived it seemed like a legit factory yuneec product inside the shippers box, ordered it on Amazon, the box says it's not compatible with the typhoon h and the website it says to check is non existent
Check out these videos
Make sure the wizzard you got is the one in the videos
You must make sure you bind the wizzard to the H
Binding starts at 2:20 in this video
Here is another video that is more indepth, note there are two parts
Part two
Pay attention to the smart circle
Does it not look like this one?
This is mine, I do not have the pro either and I bought this one on eBay and it works fine.
jhasler
