How to use Yuneec remotes with other brand drones
Hi guys,
I am back to my old Yuneec drones once again. I have slowly been moving away from Yuneec since they are not supporting any of the drones I purchased from them. I have a TON of Yuneec stuff, remotes, parts, cameras, gimbals, etc. I am trying to use some of the Yuneec equipment with other builds. One of the main things I love about Yuneec is the remote. I have several of the ST10 and ST24 controllers that I am trying to use with drones I designed and built. Before I removed the receivers from the actual drone I made sure they were bound so I would not have issues trying to bind them together. I have searched for info on this and found something interesting and wanted to share it with everyone.
It is an old archived site but still worth reading.
I'm not sure about build a FW that uses SR24 for pixhawk. It should go anyhow. I have a Pixhawk Mini to test this. It's on the ToDo list for long winter nights.
PX4 autopilot has two files st24.h and st24.c in its software bundle to make it possible to use SR24 message format.
@dylanfm has made a converter SR24 to SBUS which allows to use the STxx remote controller to use with any SBUS compatible model.
Inspired by this I have tried a connection to Raspberry Pi to control whatever I want. The project is here:
There is also a updated description of the SR24 message format, valid for ST16.
Sounds great! I will follow your project and let you know if I can contribute anything.
I want to find a way to use these Yuneec transmitters and receivers with the Pixhawk, a Naza M V2, or even an Adrucopter flight controller.
Reactions: Rony Cley Barbosa
I did a quick review of PX4 autopilot configuration. Here I found the parameter RC_INPUT_PROTO. The value for ST24 is 4.
With RC_PORT_CONFIG you can assign on which UART the SR24 is connected.
Again I must say I have not tested anything with that but it may a point to start with.
Reactions: cabinfourus
I am tied up with some other stuff right now but when I get some time I will see what I can figure out. Thanks for your input and work on this.
Hi guys,
Hey bro U don't Wana sell a camera for yuneec typhoon h do U
unfortunately only RC no telemetry, still possible to get telemetry but need a middle device like ESP32 and create some script which we can copy on thunderbird firmware
Reactions: h-elsner
To get telemetry you can use telemetry port 1 or 2 on PX4 with a MAVlink bridge V2 on ESP8266:
MAV bridge FW from Kahuna project: GitHub - BeyondRobotix/Kahuna: ESP8266 WiFi Access Point and MAVLink Bridge
→ Download latest FW release: Releases · BeyondRobotix/Kahuna
I use QGroundControl but ArduPilot should also work.
Edit Link updated.
i think i prefer this so the telemetry display on st16 are still useable
i was quick test with simple copy and paste this source to esp32 and yeah actually it works although not complete but it show voltage altitude flight mode and gps position are quite enough :)
my experiment like this
create 3 serials on esp32
1. connect to fc serial_1 (mavlink)
2. connect to fc serial_2 (RCIN)
3. connect to sr16
make passthrough between serial 2 & 3
and read every mavlink packet and send (f.e gps battery flight mode etc) encode those data with source above and injected to the serial 2 <edit Serial 3>
Reactions: h-elsner
For backwards compatibility this is a good idea. I think I will go with such a mediator device between SR24 and PX4 autopilot in some projects.
For PX4 related projects I have used the Flight mode app H520 that can deal with MAV link V2 messages from MAV bridge without additional device. This app runs on ST16 too.
Reactions: WTFDproject
mrtermite
