In need of arm latches
any got any arm latches x3 (metal clips) for Typhoon H in Australia ?, it would not land until the battery went flat just hovered
First of all welcome to YuneecPilots!
There are several issues that can cause the hovering problem you describe, but the most common is having the Rate Slider in a less than full Rabbit position during landing.
Another possibility is if you have the RealSense module and have the OBS switch (just left of the Mode switch) in the Enabled (down) position.
I replied to your other post and gave you a likely source of parts in Australia. Here is a video on replacing the clips (this can be done without removing the top shell).
In addition to DoomMeister's comment; Go to "System Settings", "Hardware Monitor", then make sure, J1 isn't Sticking, Sluggish, or not going all the way down, when you pull back on the "Left Stick" if your in "Mode 2", OR "Right Stick" if your in "Mode 1". Check J2, J3, and J4 as well. You can Test every Button, Switch, Slider, and Stick on your ST16 as well.
Reactions: DoomMeister
thierry2
