Irs keeps flashing
Before taking off, I get the irs error screen pop up every few secs till it actually takes off. Anyone know why?
mine does the same thing. says there is not enough light. so a have to set mine on a piece of white paper to get it to take off. I saw one dude try to set his on pavement and it would not takeoff.
What is the exact error you are getting?
Are you indoors or outdoors?
Is the filter cracked or dirty (fingerprints orcsmudges)?
Ensure you have good lighting. If you t do,the unit sounds like like it is close to defective. I would contact Yuneec C S and file a ticket with them. Something is not quite righ
About 12 to 18 inches? Then the status icon for it turns blue?
I do get the warning indoors if the lighting is just a little too low, but never seem to get a warning outdoors.
Justdt checked it .....the irs status is orange. When I lift it off the ground it turns blue. So I guess it's working correctly . It flashes when the area isn't well lit.
Sounds like it is working as designed.
costimarcos
