MANTIS Q camera 3rd party camera servo
Budapest, Hungary
Hi Pilots!
I have a little bit damaged Mantis Q. It is flying fine but the plastic gears in the servo were stripped.
Has anyone tryed to fit a 3rd party servo for replacement?
There is no yuneec part available for the servo only. We have buy the whole camera module. :(
But it is a 2 dollar cost servo! :)
Reactions: Yuneecforever
If I search for "micro servo" there are a couple of them available. You have to check size (l/w/h). I guess that is a standard part.
Good luck.
13,5 x 16 x 6 mm
16 x 8 x 20 mm
17.728
17.729
hi, excuse in the language this is translate google. I have the same problem with the plowshares. maybe who knows where to get a camera-only mechanism
17730
hi guys ..
first posting on this helpful community .. ;)
would like to introduce myself quickly..
my Name is Paule
I have seen 49 summer so far ;)
location Germany - Berlin
self employed graphics designer and signage manager
i bought the Mantis Q few weeks ago as used working item...
and it works roughly 10min flight time and after that ..
same issue as @dklari ...
i dismantled the Mantis gently ...
take a measure of the existing servo and search for an alternate servo at www.
i found one which have the same dimensions, but the cable connector wasn't the same ..
so i open u the old one ..
unsolder the wires and connect it to the new one..
assemble the new into the gimbal and put the batterie back on ..
on my i have to grind down the "old" gear a bit to get it centered on the gimbal gear..
not a big issue .. ;)
the servo is working ..
but i have still the issue that the mantis doesn't connect to my controller at all .. :D
so i need also a helping hand who can advise me to get the mantis back in the air :D
@dklari if your interested in getting spare part of the servo please let me know .. ;)
i´m not sure if its okay to add a link to the shop i bought my ..
anyway .. if your searching for pololu sub micro servo you will find it easily...
see attached picture of my "new gimbal" :D
thx for being a part of the community ...
cheers Paule
[QUOTE = "airview, post: 197558, član: 21666"]
bok ljudi ..
prvo objavljivanje u ovoj korisničkoj zajednici ..)
Želio bih da se brzo predstavim ..
moje ime je Paule
Do sada sam vidio 49 ljeta)
lokacija Njemačka - Berlin
samozaposleni grafički dizajner i menadžer za Signage
kupio sam Mantis Q prije nekoliko tjedana kao rabljeni radni predmet ...
i radi otprilike 10min leta leta i nakon toga ..
isti problem kao [USER = 21254] @dklari [/ USER] ...
nježno sam demontirao Mantis ...
izmjerite mjeru postojećeg poslužitelja i potražite alternativni servo na www.
Našao sam jednog koji ima iste dimenzije, ali kabelski priključak nije isti.
pa otvorim u starom ..
odmotajte žice i povežite ih s novim ..
sastavite novo u traku i vratite bateriju natrag ..
na mamu moram malo sam brusiti "stare" zupčanik da bih ga usmjerio na gimbal zupčanik ..
nije veliko pitanje ..)
servo radi ..
ali još uvijek imam problem što se mantis uvijek ne povezuje na moj kontroler ..: D
pa mi treba i pomoć koja mi može savjetovati da se mantis vrati u zrak: D
[USER = 21254] @dklari [/ USER] ako vas zanima nabava rezervnog dijela servo-ja, obavijestite me ..)
Nisam siguran da li sam smanjio vezu do trgovine koju sam kupio.
sve zajedno .. ako ovaj pololu sub mikro servo lako možete naći ...
pogledajte priloženu sliku mog "novog gimbala": D
thx zbog toga što ste dio zajednice ...
pozdravlja Paule
[/ CITAT]
pozdrav
hi guys ..
first posting on this helpful community .. )
my Name is Paule
I have seen 49 summer so far )
na mom moram malo sam brusiti "stari" zupčanik da bih ga usmjerio na gimbal zupčanik ..
nije veliko pitanje .. )
servo radi ..
ali još uvijek imam problem što se mantis uopće ne povezuje na moj kontroler .. : D
pa mi treba i pomoć koja mi može savjetovati da se mantis vrati u zrak : D
[USER = 21254] @dklari [/ USER] ako vas zanima nabavka rezervnog dijela servo-ja, obavijestite me .. )
Nisam siguran je li u redu dodati vezu do trgovine koju sam kupio.
svejedno .. ako tražite pololu sub mikro servo lako ćete ga pronaći ...
pogledajte priloženu sliku mog "novog gimbala" : D
pozdravlja Paule
[/CITAT]
Pozdrav Paule
Zanima me gdje ste nabavili i koja oznaka je servo motora
bok ljudi ..
moje ime je Paule
servo radi ..
pozdravlja Paule
[/ CITAT]
pozdrav
Hi @dklari
a little bit confusing your post .. ;)
but no worries ..
you will find the needed part on that shop Pololu Sub-Micro Servo 3.7g (Generic) - Raspberry Pi, Arduino, Robote, Motor etc. beim Eckstein Komponente, 4,95 €
hope that helps...
cheers Paule
@admin hope it´s okay if i post a link to a dealer where you can buy spare-parts...
if not please let me know and i will delete the link .. ;)
translation in your language .. ;) thx google translate
Bok @dklari
malo zbunite svoj post ..;)
ali bez brige ..
naći ćete potrebne dio na radionici radili Pololu Sub-Micro Servo 3.7g (Generic) - Raspberry Pi, Arduino, Robote, Motor etc. beim Eckstein Komponente, 4,95 €
nadam se da pomaže ...
Živjeli Paule
@admin nadam se da je u redu ako objavim vezu prodavaču gdje možete kupiti rezervne dijelove ...
ako ne, molim javite mi i izbrisat ću vezu ..;)
Pozdrav Paule
ja sam isto nesto nasao ali nisam siguran da je to.
hvala za vezu, nadam se da cu riješiti svoj problem s kamerom
Napravio sam preinaku na daljinskom upravljaču za polako kretanje drona, ako vas zanima, meni je potrebno, tražiti ako želite nešto snimiti.
Pozdrav Darko
costimarcos
