Mapping mission export
Hi all,
perhahaps a noob question but i can´t figure out how to export a mapping mission?
Any idea
thx
Lintux
You are probably getting a message telling you to complete an item in the planning or camera configuration. It will send to the H520E when you complete required items. Is that what you mean? Not export completed map data from your computer, right?
I want to export the complete configuration and map data after the mission is completed to export on my computer for using the same data/map and configuration some month later.
Click "Save" or "Save As". The file is saved in File manager in the "DataPilot" directory in a folder named "Missions". You can then copy to an SD card or use a USB cable to copy the file to a computer.
  • Save Flight Plan.pdf
Reactions: Lintux
Pefrect, thanks a fir your assistance
Bech
