More strange st16 problems
When i turn my st16 off, once its shut down the screen flickers twice then the battery sign on screen shows that its charging even tho its not plugged in.
I have to take the battery out when not in use which is a pain.
Could this be the battery itself causing this?
I hope its not another faulty st16 internal, i had first one repaired and then replaced already.
Has anyone experienced similar?
Cheers.
Did you work out why the battery is discharging ? - mine is also doing the same thing
wsc116
