Need help. firmware update crash
Hello.
I need help for typhoon h firmware updates.
someone try and crashes firmware, i dont now whats next...
camera connect to controller okay, but thats it.
now i need help for dummies whats next operation.
All firmware is up to date except the drone autopilot. It is not fully clear if you are trying to complete the firmware update or trying to bind the drone. The following guidance is offered because I think you need to bind the drone. (If the drone is not bound, the rear LED should be flashing blue.)
If the drone is already bound, please tell us the color and pattern of the rear LED.
It is hard to tell if the issue is a drone issue, a controller issue, or a process issue. Even though you have successfully bound the camera, it might be best to complete the entire binding verification process using the guidance linked below.
The verification is not just "binding instructions". It is a verification of the MANY hidden clues in the binding process. The purpose is to identify abnormal conditions that are preventing a successful bind and to identify the exact point the binding process is failing. That information can assist in determining the best course to remedy the problem.
You will need to perform every step up to the point the verification does not match what you see. Do not skip any steps. Every step must be performed. Even the steps you have no doubt are already in the correct condition. After some preparation steps, the verification falls into a routine of directing an action, then verifying the correct response to the action. When you reach a verification step that does not match what you see, or if you are unsure if it matches, STOP. Report the step number back to the forum, and what you actually saw at that step. We can then go from there.
Typhoon H Binding Verification
Binding instructions step 34 not happening.
After start that burns orange about one second. and thats it.
Problem solved.
drone need firmware update again to usb and then binding complete correct ja newest firmware install correctly
Reactions: Pier2162
jonnyelectric
