New camera problem today
Turn on the typhoon today. Camera connects quickly and is stabilised by the gimbal. Unable to get the gimbal to move with the pan and tilt controls on the ST16. Tried removing and replacing the camera and deleting and creating a new model - no change.
Sent from my E5823 using Tapatalk
Can you verify under the ST16 settings that the pan and tilt controls are actually displaying changes as you move them? Also, not sure if you have the Actioncam handle or know someone who has one but you could try to verify gimbal operation with that.
Greg
Is it a question of rebinding camera and H?
Going to refresh the firmware again
Was the camera free of grass under it. I cant get control of my gimbal at all when there is even a slight bit of pressure applied to it by the ground/grass.
If so, put it up on a table. Just a thought.
Try to remove the cam from the copter, start the copter without the cam, stop it, mount the cam correctly and start all together.
Possible you have a contact-problem at the six pins of the cam/gimbal to the copter.
Do not remove the cam from the copter or mount the cam to the copter, while it is already powerd on
Refreshed firmware and fixed problem
atas77my
