NO camera tilting and panning
So you did go through the whole process of calibrating camera?
I'm wondering if you have a loose wire connection.
How long have you had the H, did you purchase it new?
Have recently have a hard landing?
Apparently when inserting the battery it cut the cable that transmit the camera pan and tilt command so I reconnect and secure the cable and everything is working fine. Now I have full control of the camera and the gimbal can be calibrated.
Thanks AH-1G for your time and help. Screenshot_20181013-132300_Gallery.jpegIMG-20181013-WA0003.jpeg20181013_104755.jpeg
Have you removed the camera and inspected the contacts on the slide mount?
If you push slightly on the camera does it return to position or just stay where you put it?
Next thing to try is resetting the camera. There are two buttons behind the sd card slot. Use a couple of broken toothpicks and press both buttons at the same time while the camera is powered up. After the cam reboots, test it again.
Steve,
When inserting the battery it cutted one of the camera cables that prompts the tilt and pan command. I connected ans secured it and everything is working fine.
Thanks for your time and help. Screenshot_20181013-132300_Gallery.jpegIMG-20181013-WA0003.jpeg20181013_104814.jpeg
Glad you found the problem. That wire bundle should not have been inside the battery compartment.
apalomba
