Pics/video saved on st16
Was poking around on pad and discoverd the pics and video I took was there. Is there a reason for having them save to st16 memory? Can this be changed? I can just delete but if I forget I don't want all my memory eaten up.
The ST16 is set up to delete older files as new ones are created so that the memory is not affected by much.
All the media files you discovered on the ground station are only low quality files cached by your ST16 from the CGO3. The real high quality media reside all on the CGO3+ Micro SD.
The ST-16 uses a temporary folder to store a limited number of videos and photos for your review that are continuously over written. This memory is dedicated to this function. Read the attached PDF that was issued for the B22 firmware update from last year.
  • ST16 B22 What's New.pdf
ardigitalmedia
