Power switch broken
20160713_222112.jpg 20160713_222112.jpg 20160713_222112.jpg Had a crash other day..Bought new frame and installed everything from old frame..then saw power switch broken..getting no power even if I put switch back on and sitch to on doesnt want to power on..Any suggestions..picture attached
I am sure the switch is bad, did you ohm it out? If bad, I seriously doubt Yuneec will sell just a circuit board switch? But you will probably need to end up buying the whole board? Unless a electronics store carries a replacement! Board should not be too much $$$, if Yuneec will even sell it?:rolleyes:
tengo el mismo problema, se ha destruido el sw de encendido, alguien sabe si se consigue esta parte?
Robertwc
