Problem with ST 16
Good evening to everyone.
Sorry but I'm a beginner.
I have a Typhoon H, but the FLIGHT MODE app does not appear on the remote control.
The calibration does not return a positive result.
Do you have any advice?
Thanks to everyone who will answer
Have you pressed the home key on the controller ? That should
Put you in flight mode
“thank you so much.
Pressing the Home button returns to normal.
But I still do not see the app“
- Google Translate -
What do you mean by “ normal”? The Android interface? The standard Yuneec ST16 screen?
My single issue with the stickers they sent you is the "Land when voltage below 14.1V"... as if you have a choice, if waiting until 14.1V :eek:
I agree EEV. Since the photo was taken I've used my labeler to overwrite that to read 14.7 (I'm probably a bit over cautious)
[QUOTE = "rdonson, post: 138964, membro: 10662"] Marco,
Stai dicendo che non puoi tornare a vedere la normale schermata di Yuneec come mostrato di seguito?
[GALLERY = media, 747] IMG_6774 di rdonson pubblicato 13 aprile 2018 alle 2:51 PM [/ GALLERY] [/ QUOTE]
No....I see
Marco, quindi non capisco il tuo problema.
aiutami a capire
Marco, then i don’t understand your problem.
help me understand
Each to whatever makes them comfortable. For me, 14.7 is a little on the cautious side. I like to aim for 14.5. I'm comfortable with that:)
[QUOTE = "rdonson, post: 139007, membro: 10662"] Marco, quindi non capisco il tuo problema.
aiutami a capire
aiutami a capire [/ QUOTE]
Il mio problema è questo
Quando uso il Typhoon, non decolla
aiutami a capire
What Marco says: My problem is When I use the Typhoon, it does not take off
Marco:
Are you in a "No Fly Zone"?
Are you using "Smart Mode"?
Are you trying to use the Yuneec GUI?
Sei in una "No Fly Zone"?
Stai usando "Smart Mode"?
Stai cercando di utilizzare la GUI Yuneec?
Marco:
Still can’t understand what he is trying to say
Now there is a new problem.
The camcorder stays in the position as in the picture.
It does not stabilize at the center
Jakebutler
